RC10B4.1 RTR 2.4GHZ & Brushless !
...Par ici les nouveautés...le matériel...les sorties...
Les Nouveautés de nos partenaires sont publiées dans leur propre rubrique.
Pour chaque news publiée, une photo et la source sont à indiquer.
krispol
Modérateur
Modérateur
Message non lu par krispol »
Team Associated's RC10B4 has been proven as a world-class competition buggy with four consecutive IFMAR Worlds Championships and five ROAR National Championships. Equally important are the countless club and regional events that the B4 continues to win.
Designed by the winningest name in R/C, Team Associated now brings you this level of high-performance in the new RC10B4.1 RTR. Fully assembled and sharing many of the same components as the RC10B4 Team kit, the RC10B4.1 RTR incorporates upgraded features like a totally new 2.4GHz 3-Channel radio system and SHV1504 MG metal gear steering servo. A Reedy 17-turn motor supplies the power, while the XP SC200 electronic speed control with LiPo cutoff provides smooth throttle control. A sealed gear differential improves reliability and allows fine tuning for different surface conditions.
Additional upgrades can be made to your RC10B4.1 using a full line of Factory Team B4 hop-ups, as well as Reedy and LRP performance parts. Drive a genuine Team Associated RC10B4.1 RTR into the winner's circle today, or chances are you'll be chasing one!
RC10B4.1 RTR Features:
• Built on the 4-time World Champion and 5-time National Champion
RC10B4 platform
• XP3-SS 2.4 GHz 3-channel radio system with SHV1504 MG metal
gear servo
• XP SC200 electronic speed control with LiPo cutoff, forward and reverse
with reverse lock out
• Reedy 17-turn motor
• 2.6:1 ratio gearbox with sealed gear differential, dual-sided adjustable
slipper clutch, and rubber sealed ball bearings
• Molded composite low-CG chassis with set-screw antenna tube lock
• Blue aluminum shock bodies with molded pre-load clips
• Battery strap with twist-lock thumb knobs
• Rugged steel turnbuckles for adjustable camber and front toe-in
• Angled bellcrank "co-planar" steering with built in servo saver
• Vertical ball ends for roll center adjustments, front & rear
• Factory finished Interceptor 2.0 polycarbonate body
• Pre-mounted tires on white dish wheels
RC10B4.1 RTR Specifications:
Scale: 1:10
Power : Electric
Length: 377mm
Width: 250mm
Track: 214mm
Weight: 1530g
Wheelbase: 288mm
Internal Gear Ratio: 2.6:1
Drive: 2WD
:!: http://aedownloads.com/press/in_121709_ ... newsletter" onclick="window.open(this.href);return false;
ET VERSION BRUSHLESS :
Designed by the winningest name in R/C, Team Associated now brings you this level of high-performance in the new brushless RC10B4.1 RTR. Fully assembled and sharing many of the same components as the RC10B4 Team kit, the brushless RC10B4.1 RTR incorporates upgraded features like a totally new 2.4GHz 3-Channel radio system and SHV1504 MG metal gear steering servo. A Reedy 3300kV brushless motor supplies the power, while the XP SC450-BL electronic speed control with LiPo cutoff provides smooth throttle control. A sealed gear differential improves reliability and allows fine tuning for different surface conditions.
Additional upgrades can be made to your brushless RC10B4.1 using a full line of Factory Team B4 hop-ups, as well as Reedy and LRP performance parts. Drive a genuine Team Associated brushless RC10B4.1 RTR into the winner's circle today, or chances are you'll be chasing one!
RC10B4.1 Brushless RTR Features:
RC10B4 platform
gear servo
• XP SC450-BL Brushless electronic speed control with LiPo cutoff,
forward and reverse with reverse lock out
• Reedy 3300kV brushless motor
RC10B4.1 RTR Brushless Specifications:
Scale: 1:10
Power : Electric
Length: 377mm
Width: 250mm
Track: 214mm
Weight: 1530g
Wheelbase: 273mm
Drive: 2WD
:trefle: SOURCE : http://www.rc10.com/" onclick="window.open(this.href);return false;
Revenir à « Nouveautés »
